1969 Ford Mustang Oil Pressure Drop
KYLE WOODS
i have a 1969 mustang. every time i start it the oil pressure is at 41. when i rev it up it stays at 41.after about 5 minutes at idle it drops to 21.what could be the cause?
May 3, 2007 at 1:49 PM
BACKYARDMECHANIC
  • 337 POSTS
The readings you are getting are normal. You get a higher reading on the oil gauge when the car is cold and when you increase the RPMS. It's higher when cold because the oils viscosity is higher. When the oil becomes hot the viscosity thins out causing a drop in pressure. When you increase the RPMS you caused the oil pump to run faster and this will increase the oil pressure. Hope this helps.
May 4, 2007 at 12:20 AM
Suggested Repair
No repair is indicated. The expert says these oil-pressure readings are normal: pressure is higher when the oil is cold and thicker, then drops as the oil warms and thins at idle. Higher RPM also raises pressure because the oil pump turns faster.
Conversation Summary
The owner of a 1969 Ford Mustang reported oil pressure of 41 at startup and while revving, dropping to 21 after about five minutes at idle. The expert explained that this is normal because cold oil is thicker and higher RPM speeds the oil pump, while hot oil thins and lowers pressure at idle.
