1965 Ford Mustang Too Much Oil
SCHINDL2
I have a 65 mustang with a 289 v-8, and I believe that I may have put too much oil in it. So, my question has a few parts.
First, what will happen if there is too much oil in the car?
Second, how will I know if there is too much in the car?
Finally, how do I fix it? Would draining the oil and putting in new oil be sufficient?
Mar 27, 2006 at 3:25 AM
RAYHUT
  • 134 POSTS
#1 To much oil your car will not run right.
#2 check your oil dip stick to see if it's over the fill line.
#3 drain some oil to get it back to your fill line. don't drain all the oil just enough to get it back down to the full line.
Mar 27, 2006 at 3:38 AM
Suggested Repair
Check the oil dipstick. If the level is above the full line, drain only enough oil to bring it back to the full mark; do not drain all of the oil.
Conversation Summary
The owner of a 1965 Ford Mustang with a 289 V-8 believes too much oil was added and asks what happens, how to tell, and how to correct it. The expert says excess oil can make the car run poorly, advises checking the dipstick against the fill line, and recommends draining only enough oil to return the level to the full mark.
