1995 Ford Mustang Oil Flush
CHARLES27
I have a 1995 Ford Mustang V6 3.8 liter with about 70,000 miles on a rebuilt engine. Im about to change my oil and was considering using an engine oil flush before changing the oil. Are there any possible side affects to using an oil flush product that I should be aware of? Can it damage gaskets or seals? Is a oil flush something I should even concern myself with?
Aug 29, 2006 at 5:07 AM
TAURUSWHEEL
  • 718 POSTS
I wouldn't, there's no reason to use these products.. if your crankcase vent system is working properly, the engine internals should be pretty clean,, change your oil every 3k or 3 months,, it'll keep the engine like new,, here's a money-saving tip,, use Walmart Supertech oil and filters, cheap and the best you can buy..
Aug 29, 2006 at 12:43 PM
Suggested Repair
Skip engine oil flush products. Keep the crankcase ventilation system working and change the oil and filter about every 3,000 miles or 3 months. A budget oil and filter such as Walmart Supertech was suggested as adequate.
Conversation Summary
The owner of a 1995 Ford Mustang V6 3.8 with about 70,000 miles on a rebuilt engine asked whether an engine oil flush before an oil change could harm gaskets or seals and whether it is worthwhile. The expert advised against flush products, saying a properly working crankcase vent system should keep internals clean, and recommended regular oil changes every 3,000 miles or 3 months, including inexpensive Supertech oil and filters.
