1991 Ford Mustang Rear Oil Leak
RAKAVICK
I have a 1991 5.0 Mustang with 42,000 miles and I have an oil leak from the rear of the motor that is collecting inside the bellhousing. I was wondering if this was caused by a failed rear main seal? If it is the seal, what do I need to do to replace it? Is this something that I can easily do in my garage or do I need to take it somewhere to be fixed. The car is a high horsepower car with a supercharger and aluminum heads. I was wondering if that was causing the leak to happen. I do race the car and I don't want or need a fire to happen. Thanks
Jun 6, 2006 at 5:10 AM
LOSONE
  • 1,616 POSTS
The transmission has to come out and the flywheel removed. The oil seal is round and fits on the end of the crank. Get a high temperature seal before you replace it. In performance engines that end of the crank takes a lot of torque. Hopefully your rear main bearing in OK. Good luck
Jun 6, 2006 at 6:12 AM
BMDOUBLE
  • 1,139 POSTS
Congratulations on the low mileage fox body! Losone is correct, and it can be done at home with a helper.
Feb 9, 2019 at 7:28 AM
Suggested Repair
Remove the transmission and flywheel, then replace the rear main seal with a high-temperature seal. The job can be done at home with a helper. Also check the rear main bearing.
Conversation Summary
The owner of a low-mileage 1991 Ford Mustang 5.0 reports oil leaking from the rear of the engine into the bellhousing and asks whether a failed rear main seal is the cause, how to replace it, and whether it is a garage job. Experts say the transmission and flywheel must be removed to replace the round crank seal with a high-temperature seal, that the work can be done at home with a helper, and that the rear main bearing should be checked because of torque loads in a performance engine.
