1996 Ford Explorer High Beams Stay On
SHEWOLF30
Ford Explorer Sport Trac, 1996,246,000 k's, 6cylinder. Highbeam lights stay on and also the indicator on the dash stays on even when motor is off and keys removed. Have checked fuses and relays but with no luck. Have had to disconnect battery. :cry: :)
Mar 20, 2007 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
The switch should be turning them off, probably the dimmer switch, which I believe is part of the multi-function switch.
Mar 20, 2007 at 1:16 PM
Suggested Repair
Inspect the dimmer switch, which is part of the multi-function switch, because it should turn the high beams off.
Conversation Summary
A 1996 Ford Explorer Sport Trac has high beams and the dash high-beam indicator that stay on even with the engine off and the key removed. Fuses and relays were checked without success, and the battery had to be disconnected. The expert says the switch should shut them off and points to the dimmer switch in the multi-function switch.
