Ford Explorer Intermittent Low Beams
Older explorers had lamps out module (LOM). The power for both low beams goes from the fuse box thru the LOM to each individual low beam. The LOMs were prone to cracked solder joints. They can be resoldered at a considerable savings over replacement.
Trace the power (or lack of) back from the headlight connectors to the multi function switch and you will find the issue.
Good hunting and let us know. :)
Suggested Repair
Check the separate left and right low-beam fuses, headlight connectors, wiring, and fuse-box connections. On older Explorers, inspect the lamps-out module for cracked solder joints that can be resoldered. Trace power from the headlight connectors back to the multifunction switch to locate the fault.
Conversation Summary
The owner of a Ford Explorer reported that the right low beam worked intermittently, and replacing the bulb did not help. The left low beam later began doing the same, while the high beams continued to work. The expert explained that 1997-1998 Explorers have individual low-beam fuses and that older models route low-beam power through a lamps-out module prone to cracked solder joints. The recommended diagnosis is to check the fuses, connectors, wiring, and fuse-box connections, then trace power back to the multifunction switch.
