Head light
GUS102
  • FORD EXPLORER
97 EXPLORER 130K MILES LEFT HEAD LIGHT WORKS OK RT ONLY WORKS ON HIGH BEAM REPLACED BULB STILL NO LOW BEAM. HOW CAN I CK THE PLUG IN OR WIRES
Wednesday, May 23rd, 2007 AT 7:17 PM
BLACKOP555
  • 10,371 POSTS
Test the low beam headlight bulb socket wthi a voltage tester if no voltage then there is a short in the wire.
Or use a tester with a light on it to touch the positive part or the socket and ground it to the vehicle if it lights then there is a short also
Wednesday, May 23rd, 2007 AT 7:21 PM
GUS102
Thanks blacktop ill try it
Wednesday, May 23rd, 2007 AT 7:25 PM
