1999 Ford Explorer Brake Light Removal Fix
MULEPHAN30
i have a 99 ford explorer XLT. the mileage is about 160,000 and the engine size is a v6. i have a question about the brake lights. i have one out and when i tried to change it there were two screws on the top of the assembly. i took them out and tried to remove the assembly, but the assembly would not move. WHY??? i'm i missing more screws or is there an easy way of changing these brakes lights. please help!!!!! i need to get my truck inspected as soon as possible.
Apr 12, 2007 at 4:10 AM
MERLIN2021
  • 17,250 POSTS
Most of the time you unbolt the assembly from the inside...usually a 7/16ths socket, then pull the assembly out and twist the pigtail. It will come out then change the bulb...3157 I think is your number!
Apr 12, 2007 at 6:58 AM
Suggested Repair
Unbolt the brake light assembly from inside the vehicle, usually with a 7/16 socket, pull the assembly out, twist the pigtail free, and replace the bulb (likely a 3157).
Conversation Summary
The owner of a 1999 Ford Explorer XLT with a V6 could not remove a failed brake light assembly after taking out two top screws and needed it fixed for inspection. The expert said the assembly is usually unbolted from the inside with a 7/16 socket, then pulled out so the pigtail can be twisted and the bulb, likely a 3157, replaced.
