1995 Ford Explorer High mount brake light
RIVERBANDIT
  • 1995 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 200,000 MILES
The light comes on then goes out (flicker) How do I get this assembly off to check it? I found two nuts on end and removed but it looks like I have to drill rivets out to get assembly off? My Hanes manual does not cover this. Thanks Dale
Sunday, October 17th, 2010 AT 10:54 AM
HMAC300
  • 48,601 POSTS
The light bulbs and sockets should come out from behind without removing the fixture. Just look around and your shoud be able to fix it witha test light.
Sunday, October 17th, 2010 AT 11:52 AM
RIVERBANDIT
YES you can get bulbs outta side brake marker but as I said high mount. This is a neon light with a Ballast and yes I had to drill the rivets out to get to the back of the neon light, Hey found this out on a free site.
Wednesday, October 20th, 2010 AT 7:10 PM
