Rear brake third light
KEITH MCCAFFERTY
  • 1995 FORD EXPLORER
  • 200,000 MILES
The rear brake third light is not working.
Monday, June 12th, 2017 AT 11:55 AM
HMAC300
  • 48,601 POSTS
Check bulbs we have no instructions on how to replace those look for screws on outside then check the light green wire going to it for power may be the problem.
Monday, June 12th, 2017 AT 12:15 PM
KEITH MCCAFFERTY
It appears to be a sealed unit connected to exterior trim. Do you have to replace whole unit?
Tuesday, June 13th, 2017 AT 1:58 PM
HMAC300
  • 48,601 POSTS
No you shold be able to acces it from behind inside cab. Check for a removable panel to access it would be bolted from behind and give bulb access as well.
Tuesday, June 13th, 2017 AT 3:12 PM
