Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Exterior Light
Headlight
Not Working
head light
FORD EXPLORER
GUS102
MEMBER
97 EXPLORER 130K MILES LEFT HEAD LIGHT WORKS OK RT ONLY WORKS ON HIGH BEAM REPLACED BULB STILL NO LOW BEAM. HOW CAN I CK THE PLUG IN OR WIRES
May 23, 2007 at 12:17 PM
BLACKOP555
Experienced Mechanic
test the low beam headlight bulb socket wthi a voltage tester if no voltage then there is a short in the wire.
or use a tester with a light on it to touch the positive part or the socket and ground it to the vehicle if it lights then there is a short also
May 23, 2007 at 12:21 PM
GUS102
MEMBER
thanks blacktop ill try it
May 23, 2007 at 12:25 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
