2000 Ford Explorer Cylinder Pattern
JPISTORIUS
I have a 2000 Explorer Sport with about 80,000 on it I was trying to find out what the cylinder pattern was for the engine. I would assume that it would go, if you are looking toward the back of the engine to the front, 1-3 on the left 4-6 on the right. I just want to make sure though. I know there are two types of V6 on this vehicle the one I have is [b:1b3b6c3adb]not[/b:1b3b6c3adb] the SOC. Thanks for the help.
Dec 17, 2006 at 8:51 AM
CARUNDELL
  • 602 POSTS
[quote:34b6e13f8a="jpistorius"]I have a 2000 Explorer Sport with about 80,000 on it I was trying to find out what the cylinder pattern was for the engine. I would assume that it would go, if you are looking toward the back of the engine to the front, 1-3 on the left 4-6 on the right. I just want to make sure though. I know there are two types of V6 on this vehicle the one I have is [b:34b6e13f8a]not[/b:34b6e13f8a] the SOC. Thanks for the help.[/quote:34b6e13f8a]
Hey jp,
pretty sure its the other way 1,2,3 on the right (pass) side. To verify this, look at the top of the coil pack, the wire #'s should be printed on it, find #1 and trace it to the side its on!
Chris
Dec 17, 2006 at 8:30 PM
JPISTORIUS
thanks
Dec 17, 2006 at 11:52 PM
JPISTORIUS
The numbers are not on the coil pack. Do you know a site that might have a diagram on it?
Dec 18, 2006 at 11:06 AM
Suggested Repair
Treat cylinders 1, 2, and 3 as being on the passenger (right) side, opposite the assumed layout. Because the coil pack has no printed wire numbers, confirm cylinder 1 by tracing the number-one coil wire or consulting a reliable firing-order diagram before connecting plug wires.
Conversation Summary
The owner of a 2000 Ford Explorer Sport with a non-SOHC V6 asked for the cylinder numbering pattern, assuming cylinders 1-3 were on the left and 4-6 on the right when looking from the rear toward the front. The expert said it was likely the other way, with cylinders 1, 2, and 3 on the passenger side, and suggested tracing the numbered wires on the coil pack. The owner found no numbers there and requested a diagram, but no further reply was given.
