I cannot remove my oil filter. I believe it was put on improperly when i had my oil changed last. how can i get it off?
Mar 10, 2006 at 6:37 AM
Drive a large screwdriver through the oil filter and use a hammer for leverage to break it loose. Alternatively, grip the heavier base plate with large channel-lock pliers. A heat gun may help loosen it; do not use a torch.
The owner of a 1999 Ford Explorer XLT cannot remove an oil filter that is ripped open and may have been installed incorrectly at the last oil change. Experts suggest piercing the filter with a large screwdriver and using a hammer for leverage, or gripping the filter base with large channel-lock pliers. A heat gun may help, but a torch should not be used.
