2001 Ford Explorer Sport Clutch Pressure Loss Fix
2001 ALL OTHER MAKES ALL OTHER MODELS
CHRISW9000
My '01 Explorer Sport keeps losing clutch pressure. I have to put new fluid in it every morning. I cant get the tranmission in gear when I lose pressure...it really sucks being first in line at a busy red light with a bunch of cars behind me :shock: . What do I need to do?
Jan 26, 2006 at 1:17 AM
GODBEAR839
  • 77 POSTS
Sounds like the slave cylinder is leaking/going bad.
Jan 26, 2006 at 1:50 AM
CHRISW9000
Will I need to drop transmission out or is it something outside the transmission that is easy to get to?
Jan 26, 2006 at 4:21 AM
GODBEAR839
  • 77 POSTS
No you will need to drop it to change it.You should be able to see it through a hole in the bell housing to see if it is wet/or leaking at all. But in order to change it you will need to drop the transmission.If it's 4x4 it will take a bit to drop it as you have to seperate the transfer case to make life easier for yourself.
Jan 26, 2006 at 8:55 AM
Suggested Repair
Inspect the clutch slave cylinder through the hole in the bell housing for wetness or leakage. If it is leaking or failed, drop the transmission to replace it. On a 4x4, separating the transfer case makes transmission removal easier.
Conversation Summary
The owner of a 2001 Explorer Sport reports losing clutch pressure overnight and needing to add fluid every morning, which prevents shifting into gear. The expert attributes this to a leaking or failing slave cylinder. It can be checked for leakage through a hole in the bell housing, but replacement requires dropping the transmission; on a 4x4, separating the transfer case makes the job easier.
