1999 Ford Explorer Gas Fumes
ROBETTE30
Have a 1999 ford explorer with 67,000 miles, 4.0, 2wheel drive. Had a new fuel pump put in a couple of months ago. Since then my check engines light comes on. So I go to auto zone and have them check it and it comes back with bad gas cap. Have replaced 3 times, still gas fumes. Fumes are worse when I fill my tank fuel and can smell them bad until the tank is just at half and under. Any answers to why since I had it in the shop? Also should I be driving with kids in car, today it smelled like it could blow up anytime. Can the replacement of the fuel pump have anything to do with the fumes when they fixed it?
Jun 5, 2007 at 1:57 PM
SERVICE WRITER
  • 9,123 POSTS
I have seen several fuel filler necks leak on these. Look closely around the seat of the neck where the cap rests on. Is there any cracks? Also severe corrosion will allow it to release fumes. Check the codes in the computer. If a evaporative code comes up, have the system smoked. Those necks aren't cheap :shock:
Jun 5, 2007 at 2:07 PM
ROBETTE30
Are you saying that I shouldn't be driving the explorer? Also, about how much am I looking at to replace the neck?
Jun 5, 2007 at 2:21 PM
SERVICE WRITER
  • 9,123 POSTS
Well, fumes are explosive....will you have a problem? I dunno. It's up to you to drive or not.
At our shop labor runs about 35-70 to install, the neck is around $300 I think. But it all depens on the area your in. Call around and ask or go to a shop you trust better yet.
Jun 5, 2007 at 2:39 PM
ROBETTE30
Thank you!
Jun 5, 2007 at 2:48 PM
SERVICE WRITER
  • 9,123 POSTS
My pleasure.
You should get the codes read and have the system
checked with a smoke machine if an evap code shows before you do replace anything.
Jun 5, 2007 at 10:59 PM
Suggested Repair
Inspect the fuel filler neck seat for cracks or severe corrosion. Read the codes and, if an evaporative emissions code is present, have the EVAP system smoke-tested before replacing the filler neck.
Conversation Summary
The owner of a 1999 Ford Explorer reports strong gas fumes after a fuel pump replacement, especially after filling the tank until it drops to about half. A parts store blamed the gas cap, but three replacements did not stop the fumes. The expert says filler necks commonly leak on these vehicles and recommends inspecting the neck seat for cracks or corrosion, reading codes, and smoke-testing the EVAP system before replacing anything. Labor was estimated at about $35-70 and the neck around $300, depending on location. Whether to drive is left to the owner because fuel fumes can be explosive.
