1995 Ford Explorer Injector Cleaning
JIM.D
1995 EXPLORER 130,000 MILES. FUEL INJECTORS ARE UNTOUCHED ORIGINALS. DUE TO GAS COSTS IS IT COST EFFECTIVE TO INSPECT AND CLEAN/OVERHAUL THE INJECTORS OR IS OPENING THEM UP ASKING FOR TROUBLE! CAR RUNS FINE.
May 12, 2006 at 7:28 AM
PEPPERMRJ
  • 1,158 POSTS
IMHO just run a tank of gas with fuel injector cleaner thru evry so often. I like Chevron Techron myself. There is a screen that can be cleaned on ford injectors and there are professional cleaning services available locally and online. I would do neither as long as the engine is running properly.
Fuel savings tips abound everywhere with the advent of $3.00 a gallon gas. Here are a few of my favorites.
Be sure of the proper operation of the thermostat. A stat that is stuck (open) will not allow the engine to reach operating temperature quickly if at all. The computer interprets this as a cold engine and provides a richer air fuel ratio.
Lighten the load. Auto manufacturers went to compact spare tires and plastic/composite materials to save weight and reach mandated fuel economy goals. Take the junk out of the trunk!
Put a quarter on the dash. Drive in a manner that will not cause the quarter to move. Fast start,stops, and turns all waste fuel.
Good luck. :)
May 12, 2006 at 1:21 PM
Suggested Repair
Do not open, inspect, or professionally clean the original injectors while the engine runs properly. Periodically run a tank of gas with a quality fuel injector cleaner such as Chevron Techron. For fuel economy, confirm the thermostat reaches operating temperature, reduce unnecessary weight, and avoid hard acceleration, braking, and cornering.
Conversation Summary
The owner of a 1995 Ford Explorer with 130,000 miles asked whether untouched original fuel injectors should be inspected, cleaned, or overhauled to save fuel, noting that the vehicle runs fine. The expert advised against opening or professionally cleaning the injectors while the engine runs properly and recommended occasional use of fuel injector cleaner such as Chevron Techron, along with basic fuel-economy checks.
