1998 Ford Explorer Fuse 14 Blows
MRBECKHAM1978
  • 6 POSTS
I JUST RECENLY INSTALLED A REBUILT MOTOR INTO MY 98 FORD EXPLORER SPORT... (V6 4.0 SOHC), AND I'M HAVING A PROBLEM WITH THE #14 FUSE SLOT IN THE POWER DISTRIBUTION BOX UNDER THE HOOD... IT BLOW'S THAT FUSE EVRYTIME I CONNECT THE BATTERY... WHAT CAN THE PROBLEM BE?
Jan 6, 2007 at 3:15 PM
CARUNDELL
  • 602 POSTS
[quote:fee87ad458="mrbeckham1978"]I JUST RECENLY INSTALLED A REBUILT MOTOR INTO MY 98 FORD EXPLORER SPORT... (V6 4.0 SOHC), AND I'M HAVING A PROBLEM WITH THE #14 FUSE SLOT IN THE POWER DISTRIBUTION BOX UNDER THE HOOD... IT BLOW'S THAT FUSE EVRYTIME I CONNECT THE BATTERY... WHAT CAN THE PROBLEM BE?[/quote:fee87ad458]
Hey mr beckham,
what does the #14 fuse power up? it should state that in your owners manual or repair manual. Get back to me and I can help you more!
Chris
Jan 6, 2007 at 10:26 PM
MRBECKHAM1978
  • 6 POSTS
[quote="carundell"][quote="mrbeckham1978"]I JUST RECENLY INSTALLED A REBUILT MOTOR INTO MY 98 FORD EXPLORER SPORT... (V6 4.0 SOHC), AND I'M HAVING A PROBLEM WITH THE #14 FUSE SLOT IN THE POWER DISTRIBUTION BOX UNDER THE HOOD... IT BLOW'S THAT FUSE EVRYTIME I CONNECT THE BATTERY... WHAT CAN THE PROBLEM BE?[/quote]
Hey mr beckham,
Chris
The # 14 fuse in the power distribution box is for the generator/voltage regulator...
Jan 7, 2007 at 3:24 AM
MRBECKHAM1978
  • 6 POSTS
Jan 7, 2007 at 3:26 AM
CARUNDELL
  • 602 POSTS
Interesting ...... I would start by electrically disconnecting the alt and see if the fuse still blows, if it does, then somewhere the harness is shorted. if not, then the alt is shorted (unlikely as it may seem)
Chris
Jan 7, 2007 at 4:07 AM
MRBECKHAM1978
  • 6 POSTS
Thank you man... I will try this asap... thanks again
Jan 7, 2007 at 4:10 AM
CARUNDELL
  • 602 POSTS
My pleasure!!
Chris
Jan 7, 2007 at 4:26 AM
MRBECKHAM1978
  • 6 POSTS
I tried all of the electrical outlets and even replaced the full line, and that didn't work... do you think that the computer needs to be changed? it's the same exact motor?
Jan 7, 2007 at 5:33 PM
MRBECKHAM1978
  • 6 POSTS
i finally got it to turn over now... do you think that the computer needs to be reset? if so, what's the procedure?
Jan 11, 2007 at 5:36 PM
Suggested Repair
Electrically disconnect the alternator and reconnect the battery. If fuse 14 still blows, the generator circuit harness is shorted; if it does not, the alternator is internally shorted. The later computer replacement and reset questions were not answered.
Conversation Summary
After installing a rebuilt 4.0 SOHC engine in a 1998 Ford Explorer Sport, the owner reported that underhood power distribution box fuse 14, identified as the generator/voltage regulator fuse, blew whenever the battery was connected. The expert advised disconnecting the alternator electrically: a fuse that still blows points to a shorted harness, while a fuse that holds points to a shorted alternator. The owner later said wiring work did not fix it, then reported the engine would turn over and asked about replacing or resetting the computer, but those questions received no expert reply.
