1999 Ford Explorer Washer Fuse Blows
DDELLIOTT18
I have a 1999 Ford Explorer Eddie Bauer Edition with 105,000 miles on it. I keep blowing a fuse. The only things on the fuse are the windshield washer pump and relay. I have replaced the pump. It happens quite often.
Feb 19, 2007 at 5:14 AM
CHEVY22
  • 1,375 POSTS
well there are a few more things in that circuit, there is the relay , a generic module behind the dash , the multifunction switch, wiper motor and washer pump motor and if you have rear wipers there is also wiring that goes to the liftgate
Feb 19, 2007 at 6:31 AM
Suggested Repair
Inspect the rest of the washer circuit, not just the replaced pump: the relay, generic module behind the dash, multifunction switch, wiper motor, and liftgate wiring if the vehicle has rear wipers.
Conversation Summary
The owner of a 1999 Ford Explorer Eddie Bauer with 105,000 miles reports a fuse that repeatedly blows. The circuit covers the windshield washer pump and relay, and the pump has already been replaced. An expert says the circuit also includes the relay, a generic module behind the dash, the multifunction switch, the wiper motor, and liftgate wiring if rear wipers are equipped.
