Engine problem
2000 Ford Explorer 6 cyl Front Wheel Drive Automatic 195.36 miles
idols high then low sometimes cutting off.
Sunday, January 6th, 2008 AT 2:20 PM
MUSTANG87
MECHANIC
Sounds like you need to replace the idle control valve. But check all air hoses that go to throtle body, make sure none are bad. Then try the idle control valve.
