HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Brakes
Rotor
2000 Ford Explorer disc-brake rotor
CARMAN379
MEMBER
2000 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
135,000 MILES
I need help taking off rear rotor
Saturday, December 29th, 2007 AT 4:15 PM
BMRFIXIT
MECHANIC
Rear brake rotor
make sure E brake loose
also u can loosen E brake shoes so u can pull out the rotors
SPONSORED LINKS
Saturday, December 29th, 2007 AT 10:47 PM
Please
login
or
register
to post a reply.
Related Brake Rotor Content
Car Question
I Have A 2000 Ford Explorer And The Brakes Are Bad In The Back And One Of The Rotor Are Bad I Was Wondered Can U Use Used Rotors Or Do U...
Asked by
tonyahammer25
2000
FORD EXPLORER
GUIDE
Rotor Stuck on Hub/Axle
Much like a rear brake drum that gets stuck to the axle flange, a brake rotor is subject to the same type of problem due to the fresh metal on both the brake rotor and the...
What Makes And Years Of Other Fords Have...
What Makes And Years Of Other Fords Have Interchangable Front Rotors
Asked by
Anonymous
1 ANSWER
2000
FORD EXPLORER
2006 Ford Explorer Rear Rotors
I Cannot Get The Rear Rotors To Release. I Have Removed The Tire And The Caliper But Cannot Get The Rotor Off. What Am I Doing Wrong?
Asked by
karcourt
2006
FORD EXPLORER
2003 Ford Explorer Rear Brake Rotors
How Do You Get The Rear Brake Rotors Off? I Have Taken The The Pads And Caliper Off, And Removed The Center Nut That Holds The Rotor On...
Asked by
rjallen126
1 ANSWER
2003
FORD EXPLORER
2005 Ford Explorer Removing The Rear Brake Rotors
Brakes Problem 2005 Ford Explorer 6 Cyl Four Wheel Drive Automatic Last Weekend, I Tried To Replace The Rear Brakes In Our 2005 Ford...
Asked by
kbrandel4314
2005
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Brake Rotor Replacement
Brake Rotor Symptoms
Axle Bearing CV Bearing Replacement
Online car repair manuals
