Engine Mechanical problem
1999 Ford Explorer 6 cyl Two Wheel Drive Automatic
how to clean out a fuel fail
Saturday, February 20th, 2010 AT 7:17 PM
MECHANIC
Disconnect the supply line, return, and the regulator and blow it out with air pressure. THen I recommend spraying carb cleaner into it and blowing it out again. Do this a few times until all appears clean.
