2000 Ford Explorer Intermittent fading brake pedal
CAPTAINBART
  • 2000 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 77,000 MILES
This problem has been going on for some 18 months. The brake pedal will intermittently fade to within 1/2" of the floor before the brakes grab. Releasing and reapplying the brakes yields normal brake pedal travel and action. This happens frequently after climbing a moderate hill or spending some time at speed on the freeway. It rarely or never happens when driving around town or with frequent accelerator changes.
I have replaced the master cylinder twice, the ABS module once and the rear speed sensors once with no success.
With my limited knowledge it seems that it might be a vacuum problem but I have been assured that the power boost checks out okay, no leaks.
The last repair, the speed sensors, came from a shop which claimed to have checked with a Ford specialist who said this was not an uncommon problem with the speed sensor. My local Ford Dealer has never heard of the problem.
Wednesday, December 16th, 2009 AT 12:09 PM
BMRFIXIT
  • 19,053 POSTS
Is like when you at a very slow speed almost near stopping and the brake paddle fade and you hear a clicking and the truck stops
what I think is happening is that the ABS is being activated
most common ive seen an open ABS ring
Wednesday, December 16th, 2009 AT 5:09 PM
CAPTAINBART
No. The problem only happens at speed, sometimes high speed on the freeway. And there is no sound associated with the problem, just an almost complete fade of the pedal to less than 1/2" from the floor before the brakes work. So far they have always worked.
Thursday, December 17th, 2009 AT 2:46 PM
BMRFIXIT
  • 19,053 POSTS
I see
so it OK so far
do you have rear drums or rear calipers
if it happens again let me know
Thursday, December 17th, 2009 AT 5:06 PM
CAPTAINBART
Sorry for the delay in responding but I was out or town.
I have 4-wheel disc brakes. And yes it happens everytime I drive the car.
Sunday, December 27th, 2009 AT 6:48 PM
BMRFIXIT
  • 19,053 POSTS
Was the brake fluids flushed?
I would do so as every thing else was checked and or replaced
Monday, December 28th, 2009 AT 6:29 AM
