1999 Ford Explorer Cold Starting
JEFFREY PUCCIO
Engine problem
1999 Ford Explorer V6 Four Wheel Drive Automatic 54000 miles
At cold temperatures my explorer stalls out unless I keep the accelerator depressed for a few minutes until it warms up and then it will remain idling. I replaced the idle and control valve but still have the problem .. Any suggestion ??
Thanks
Dec 2, 2007 at 5:16 AM
  • 75,988 POSTS
Get the coolant temperature sensor check this is the one that gives fuel for an initial cold starts similar to a carbuerator choke
Dec 2, 2007 at 5:25 AM
  • 55,743 POSTS
Nope, that will not help, you need to service the throttle bore, this guide will help.
Please check out the images below to see how the job is done on our car. Check out the images (below). Please let us know what happens.
Jun 25, 2024 at 8:31 AM
