1994 Ford Explorer Stalls After Start
LOVEPIRATE89
1994 ford explorer xlt 137,000 miles
recently my truck when i start it will stall out. it has happened twice so far, but nevertheless it bugs me as to what it may be. the first time i drove it and it was fine, i drove it to the store. i turned it off. when i went to leave, it wouldnt start, it would shoot but not fire, as if the engine wasnt recieving any gas.
the second time this occured it started up fine, i put it in reverse to back out of my yard, and it stalled out. i started it again and had to repeatedly push on the gas pedal then it started.
could this be my fuel pump/filters? i was told there is a slight chance its my spark plugs so im going to check those tonight and buy new ones if thats the case.
any comment would be GREATLY appreciated. thank you very much.
Apr 11, 2007 at 3:48 AM
BAREFOOTBOB88
  • 60 POSTS
Well. If the truck stalls out intermittently chances are its not the plugs, but would be a good thing to check if they haven't been changed in 6,000 or so miles. It seems as though it could be a dirty filter. That would be one of the simpler things to change. Before going through the trouble of changing the fuel filter you should try a simple test by just turning on the key and listening for the fuel pump. I am not sure if your year of truck has two fuel pumps or not. If it does the easiest pump to listen for would be the inline fuel pump just under the driver side door. Its usually mounted on the inner side of the frame. Or you can also listen for the pump in the tank. Do this test a couple of times. If there is a time or two the pump(s) don't kick on it's pry your fuel pump relay. Thats usually a snap to replace.
Apr 11, 2007 at 12:16 PM
MERLIN2021
  • 17,250 POSTS
First off if you have worn electrodes on the plugs tou can experience these symtoms...Hard starting is a sign you need a tune up...wires and all...I'm not saying you don't have a fuel pump problem but you CAN pressure test a fuel pum.
Apr 12, 2007 at 10:04 AM
Suggested Repair
Check spark plugs and ignition wires as part of a tune-up, since worn electrodes can cause hard starting and stalling. Also pressure-test the fuel pump before replacing it.
Conversation Summary
A 1994 Ford Explorer intermittently stalls after starting, sometimes cranks without firing as if it is not getting fuel, and once stalled in reverse until the accelerator was pumped. A reply suggested the plugs were less likely, and recommended checking a dirty fuel filter, listening for the pump to prime, and considering the fuel pump relay. The expert said worn plug electrodes and ignition wires can cause these symptoms and advised a tune-up plus a fuel-pump pressure test.
