1991 Ford Explorer Fuel pump
DEMOMA3
  • 1991 FORD EXPLORER
Engine Mechanical problem
1991 Ford Explorer 6 cyl Two Wheel Drive Manual
My 91 explorer was acting like it was out of gas and died I put gas in but it wont start. Could it be the fuel pump or what>would a fuel pump for a 91 f150 be compatible?
Wednesday, May 27th, 2009 AT 12:03 AM
The fuel pump is not compatible as for could be the fuel pump you need to check the fuel pressure to ruel it out, before you start on the fuel pump best check if you're getting ignition spark
Wednesday, May 27th, 2009 AT 12:56 AM
