2002 Ford Explorer Electrical fuel module
105,698 MILES • 6 CYL • 4WD • AUTOMATIC
KRISTINA FOLEY
I have a 2002 Ford Explorer with just over 100,000 miles on it. My concern is this; one to two times a day the truck does not start. The battery is brand new, alternator checks out fine as well. We can hear the engine trying to turn over, the fuel is not getting to the engine. We have been to the dealer and the truck starts everytime of course, therefore no codes from the computer to report. (When you hear the high pitched sound right after turning the key, you know it will start) One mechanic tells us it's the the fuel pump, another mechanic says that it's the module under the dashboard on the passenger side of the vehicle. What is your take on this rather perplexing situation?
Aug 26, 2008 at 8:41 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad pump, or possibly fuel pump relay.There is an inertia switch behind pass side kick panel, under "A" pillar. When it wont start, test for power in and out of it with a test light, this is the last stop before the fuel pump.If no power into it, the relay likely isnt feeding power and could be the problem, if it has power in and out, the fuel pump is most likely bad (wire colors are - dark green/yellow, pink/black
Aug 27, 2008 at 1:11 AM
