1991 Ford Explorer Dies After Jump Start
ANDYTI
I'm sure this has been questioned hundreds of times but I can't pin-point the answer. Thanks in advance for your advice!
We've got this Explorer that was starting fine until today. Rapid clicks when the key is turned. She was left sitting for 10 hours and started right up but then, I tried to lower the power window and she died.
So I jump started her and she fired right up. When I disconnected the cable, she died.
I guess if I leave the good car running and connected a while, the dead battery can charge up a bit more and hopefully she'll keep running?
What do you think is the root of this issue? Old battery, alternator? Battery cables are pretty corroded. I'm gonna clean and re-attach those thoroughly tomorry.
Ford
Explorer
1991
90,000
Jul 22, 2006 at 4:13 PM
TAURUSWHEEL
  • 718 POSTS
If the charging system is good, the car will run, if the charging system is bad, it'll run until the battery is too low to power the car, that's what reserve capacity is for,, that's the number of minutes in theory the car will continue to run, usually listed as 120 minutes, something along those lines,, give the wiirng a good cleaning..
Jul 23, 2006 at 3:25 AM
ANDYTI
Thanks! I went ahead and replaced the battery and alternator and now she's good to go.
Jul 23, 2006 at 2:27 PM
Suggested Repair
Clean corroded battery cables and connections. If the engine dies as soon as the jump cables are removed, test and replace the battery and alternator as needed.
Conversation Summary
A 1991 Ford Explorer clicked when cranked, died when a power window was used, and stalled as soon as jump-start cables were disconnected. The expert said a good charging system should keep the engine running and advised cleaning the wiring. The owner replaced the battery and alternator, after which the Explorer ran normally.
