I had the same type of problems with my 93 explorer. The engine would die, and after a short time, I could get it to run again.
My problem turned out to be a faulty relay. It was the electronic engine controls relay (EEC). It is a relay in the power distribution center under the hood. There is a box with relays and fuses. I think all the relays are the same. Try switching the blower relay with the EEC relay and see if that is the problem.
I have had to replace 2 of these relays in my Explorer.
If it is the relay, they are readily available at your local auto parts store for about $5.
Good luck
If we help, let us know. We are all volenteers and we love to help out. If you like our advice, vote for us.
Sunday, February 25th, 2007 AT 11:04 PM
