1986 Ford Bronco II Rich Black Smoke
CHANDLER
Hello, I have a 1986 Ford Bronco II 4x4 XLT fuel infected with and automatic transmission and a 2.9 liter V6. My problem is that it's running really rich smoking black puffs of smoke out of the exhaust i hooked it to a scanner and it says insufficiant EGR flow and thats it. but it doesnt smoke when im accelarating or if i have my foot off the gas only when im trying to maintain speed it blow out puffs of smoke. I have no idea what to check i heard it could be many things. If you could please help me i would really appreciate it. Thanks
May 29, 2007 at 6:21 AM
RUDPRO
  • 224 POSTS
First, with the engine cold, start it, wait 1-2 minutes and feel the EGR valve. It should not be hot. If it is, the valve is stuck open, replace it. To test further, follow this procedure:
Install a tachometer on the engine.
Detach the engine wiring harness connector from the Idle Air Control (IAC) solenoid, it's on the side of the throttle body.
Disconnect and plug the vacuum supply hose from the EGR valve.
Start the engine, then apply the parking brake, block the rear wheels and position the transmission in Neutral.
Observe and note the idle speed.
If the engine will not idle with the IAC solenoid disconnected, provide an air bypass to the engine by slightly opening the throttle plate. Do not allow the idle speed to exceed typical idle rpm.
Attach a hand operated vacuum pump to the EGR valve vacuum port. Slowly apply 5-10 in. Hg (17-34 kPa) of vacuum to the EGR valve. You should see movement of the EGR valve stem.
If the idle speed drops more than 100 rpm with the vacuum applied and returns to normal after the vacuum is removed, the EGR valve is OK.
If the idle speed does not drop more than 100 rpm with the vacuum applied and return to normal after the vacuum is removed, inspect the EGR valve for a blockage; clean it if a blockage is found. Replace the EGR valve if no blockage is found, or if cleaning the valve does not remedy the malfunction.
May 29, 2007 at 2:26 PM
Suggested Repair
With the engine cold, start it and feel the EGR valve after 1-2 minutes; if it is hot, it is stuck open and should be replaced. If not, test the valve with a vacuum pump and tachometer: apply 5-10 in. Hg and confirm the stem moves and idle drops more than 100 rpm. Clean a blocked valve, or replace it if cleaning does not restore proper operation.
Conversation Summary
The owner of a 1986 Ford Bronco II with a 2.9L V6 reports a rich condition and black exhaust smoke only while maintaining speed, plus a scanner code for insufficient EGR flow. The expert recommends checking whether the EGR valve is stuck open when cold, then testing it with vacuum to confirm stem movement and an idle-speed drop. A blocked valve should be cleaned; replace it if it remains faulty.
