1985 Ford Bronco Brakes Tighten
DONNY BRYSON
  • 13 POSTS
I just installed new brakes on the rear of my bronco. The problem I was having is it seems the futher I drive my brakes are getting tight. I did have a bad wheel cyclinder. I replced both sides and new hardware along with shoes. I blead the lines. But I still have the same problem. Did I not get all the air out maybe?
Jun 16, 2007 at 10:25 AM
MIKE H R
  • 3,094 POSTS
with air in the lines you would be getting less brakes. If the truck was ok before and now it tightens up i would take the wheels off and check for something loos or the brake adjusters are not in right.
Jun 16, 2007 at 1:40 PM
DONNY BRYSON
  • 13 POSTS
I had the same problem befor changing out the rear .I also have new calipers on the front and a new master cyclinder too.
Jun 17, 2007 at 12:08 AM
MERLIN2021
  • 17,250 POSTS
Did you turn the drums? an out of round drum will cause this problem...
Jun 18, 2007 at 2:11 AM
MIKE H R
  • 3,094 POSTS
check the drums as merlin mentioned. When you have the drums off check to see if the e-brake is hanging up and that everything is tight {not the brakes} and working ok. Check the brake lines to see if they could have been pinched.
Jun 18, 2007 at 9:36 AM
DONNY BRYSON
  • 13 POSTS
I fixed the problem today it turned out to be a bad brake booster. The buster was holding the vacum every time I would mash the peddled they were geting tighter and tighter . THANK YOU ALL FOR YOUR HELP
Jun 18, 2007 at 10:56 AM
MIKE H R
  • 3,094 POSTS
sorry i did not pick up on that, with reading your post i was thinking your back brakes were getting tighter instead of all your brakes.
Jun 18, 2007 at 2:28 PM
Suggested Repair
Replace the brake booster. A booster that holds vacuum can apply the brakes more tightly with each pedal press. Also inspect drums for being out of round, check that the parking brake is not hanging up, and look for pinched brake lines or incorrect adjusters.
Conversation Summary
After new rear shoes, wheel cylinders, hardware, front calipers, and a master cylinder, a 1985 Ford Bronco's brakes tightened the farther it was driven. Bleeding did not help. Suggestions included checking for air (which would reduce braking), loose parts, incorrect adjusters, out-of-round drums, a hanging parking brake, and pinched lines. The owner later found a bad brake booster holding vacuum and applying the brakes harder with each pedal press.
