1990 Ford Bronco
JS577677
  • 1990 FORD BRONCO
  • V8
  • 4WD
  • 156,312 MILES
When I put my bronco in reverse, it drags. It almost will not back up. It feels like the e brake is on but it is not. What could be the problem. Funny thing though, it drives fine going forward?
Sunday, May 24th, 2009 AT 12:51 PM
DRAGGING BRAKES May create a steering pull and/or increased fuel consumption. Caused by weak or broken retracting springs on drum brakes, a jammed or corroded caliper piston, a floating caliper with badly corroded mounting pins or bushings (uneven pad wear between the inner and outer pads is a clue here), overextended drum brake self-adjusters or a sticky or frozen emergency brake cable.
Sunday, May 24th, 2009 AT 6:45 PM
