1988 Ford Bronco Rich Exhaust No Idle
CALEBP
i have a 1988 full size ford bronco. the exaust smells realy rich and the motor doesnt idle it sounds like eather the oxidation level is off or just to much feul. can u help me with this. i dont know how many miles are on it.o ya my engine is a 302 5.0 liter and it is a automatic with no overdrive
Sep 22, 2007 at 8:15 PM
  • 75,988 POSTS
[quote:3fbf101898="calebp"]i have a 1988 full size ford bronco. the exaust smells realy rich and the motor doesnt idle it sounds like eather the oxidation level is off or just to much feul. can u help me with this. i dont know how many miles are on it.o ya my engine is a 302 5.0 liter and it is a automatic with no overdrive[/quote:3fbf101898]
Disconnect the exhaust pipe at the exhaust manifold and see what happens could be clogged-up do this 1st and comeback with your findings. Remember am the technician here now-I call the shot.
Sep 22, 2007 at 8:27 PM
Suggested Repair
Disconnect the exhaust pipe at the exhaust manifold and check whether a clogged exhaust is causing the rich smell and poor idle, then report the results.
Conversation Summary
The owner of a 1988 Ford Bronco with a 5.0L 302 and automatic transmission reports a rich exhaust smell and no idle, suspecting a mixture or fuel problem. Mileage is unknown. The technician advised disconnecting the exhaust pipe at the manifold first to check for a clogged exhaust and then reporting the findings.
