1987 Ford Bronco No-Start Battery Cable Fix
ADAM351
I have an full size '87 Ford Bronco with a 351 with an odometer which reads 156396. The vehicle has sat since it left me stranded about four months ago,I had jumped it and drove it home with no problems. Now everytime I try to start it, the vehicle sparks at the battery and then it is completly dead until I mess around with the cables. I replaced the battery and the alternator. It worked that night(I shut it off and restarted it with no problems) the next morning it sparked upon starting and then was dead again. I didn't touch it for a week and tonight when I went back to it, the negetive terminal was fizzing and when I pulled the cable off it had been partially disolved. I have no clue what is going on and would appreciate any help that anyone could offer. Thank you for taking the time to read all of this.
akf
Apr 15, 2007 at 3:45 PM
  • 75,988 POSTS
[quote:5bf1bba43e="Adam351"]I have an full size '87 Ford Bronco with a 351 with an odometer which reads 156396. The vehicle has sat since it left me stranded about four months ago,I had jumped it and drove it home with no problems. Now everytime I try to start it, the vehicle sparks at the battery and then it is completly dead until I mess around with the cables. I replaced the battery and the alternator. It worked that night(I shut it off and restarted it with no problems) the next morning it sparked upon starting and then was dead again. I didn't touch it for a week and tonight when I went back to it, the negetive terminal was fizzing and when I pulled the cable off it had been partially disolved. I have no clue what is going on and would appreciate any help that anyone could offer. Thank you for taking the time to read all of this.
akf[/quote:5bf1bba43e]
Better check the battery cable at the starter relay can be shorting out to ground
Apr 15, 2007 at 11:30 PM
ADAM351
I replaced the positive terminal cable and the truck started right up Thank you very much for your help.
Apr 17, 2007 at 2:31 PM
Suggested Repair
Inspect the positive battery cable at the starter relay for a short to ground, and replace the positive battery cable if it is damaged or corroded.
Conversation Summary
The owner of a 1987 Ford Bronco with a 351 reported that it would not start unless jumped, sparked at the battery, then went dead until the cables were moved. A new battery and alternator did not fix it, and the negative terminal later fizzed and partially dissolved. The expert advised checking the battery cable at the starter relay for a short to ground. The owner replaced the positive cable and the truck started normally.
