When I turn the key the starter turns over and all you hear is a loud tingy sound like maybe the starter isnt against the fly wheel or something like that. What do you think?
1984 Ford Bronco II Starter Tingy Noise
When I turn the key the starter turns over and all you hear is a loud tingy sound like maybe the starter isnt against the fly wheel or something like that. What do you think?[/quote:49dc6842ba]
Could be your starter relay or the starter itself
When I turn the key the starter turns over and all you hear is a loud tingy sound like maybe the starter isnt against the fly wheel or something like that. What do you think?[/quote:7ce1d323fd]
Could be your starter relay or the starter itself[/quot
e]
Thanks,But my starter is fully functionable.It has no problem turning over its just the sound that is with turning over.Any ideas now.(Its kinda hard to explain.)
Could be that the drive pinion of the starter is gone or to far from the F/P, missing teeths on the flexplate/flywheel or an intermittent clutch assy slipping-in the starter.Break it open and investigate.
Suggested Repair
Inspect the starter relay and starter drive pinion engagement with the flexplate or flywheel. Check for missing flywheel teeth and a slipping starter clutch. Also inspect the broken upper bellhousing bolt holes and whether the engine and transmission have separated, since the truck starts only when push-started.
Conversation Summary
The owner of a 1984 Ford Bronco II said the starter spins with a loud tingy noise and the engine will not start unless the vehicle is push-started. An expert suggested checking the starter relay, starter drive pinion, flexplate or flywheel teeth, and starter clutch, and advised inspecting the starter area. The owner also reported broken upper bellhousing bolt holes and suspected the engine and transmission were pulling apart, but no confirmed repair was completed.
