1990 Ford Bronco Oil Smoke from Breather
NASHOLMM
I have oil smoke blowing out of oil fill breather tube going to air cleaner. #7 spark plug is getting a dark brown in color.all other plugs are coming out clean and white. i suspect #7 cylinder is the problem any sugestions on what could be wrong. am hoping for a simple fix.
Thanks Michael
Jun 16, 2007 at 5:45 AM
INDYUKE
  • 416 POSTS
Do a cylinder leak down test. That will give you a good indication of whether or not your rings are bad. That's what it sounds like.
You can also stick a borescope in there and see if the cylinder walls are scored badly or if you have a cracked piston.
Jul 12, 2007 at 6:51 PM
Suggested Repair
Perform a cylinder leak-down test, focusing on cylinder 7, to check for bad rings. Use a borescope to inspect for scored cylinder walls or a cracked piston.
Conversation Summary
The owner of a 1990 Ford Bronco 5.0 reports oil smoke from the oil-fill breather tube to the air cleaner and a dark brown No. 7 spark plug while the other plugs are clean. The expert says this sounds like bad rings and recommends a leak-down test plus a borescope inspection for scored walls or a cracked piston.
