I'll try stater fluid, but I just put a new pump. With the pump that was there when it had shorting, the engine never attempted to run and there was no strong petrol smell that am getting this time.
SPONSORED LINKS
Wednesday, May 20th, 2020 AT 1:58 PM
MECHANIC
Okay. If you can smell fuel then I suspect it will not start with starter fluid. If not, you need to pull a plug and hold it against the block and crank the engine to check for spark.
Wednesday, May 20th, 2020 AT 7:48 PM
VABBIED
MEMBER
I tried to start it with MAF sensor disconnected it failed to run then I connected the sensor back, it started with full power like magic.
The engine is now running smoothly
Monday, May 25th, 2020 AT 10:57 PM
MECHANIC
That is an interesting one. So, disconnecting and reconnecting the MAF has repaired it?
Let us know. Regardless, I'm glad to hear it's running for you.
