Started to overheat turned off engine now will not start
102,000 MILES • 4.0L • AUTOMATIC
ECALLY77
Car was working normally, no issues of any kind. I noticed the over heating sign and stopped immediately. I tried starting the car and it would not start at first try. Before I could start the car again, the mechanic removes the battery head to tighten it properly.
Before fan system was dismantled and changed (which got the fan working faster and finer than before), I noticed that the car would start then stop after a few seconds without putting it in gear.
After the fan was installed, I noticed the car would start when not in gear but as soon as it's on drive or reverse, it jerks and stops.
An urgent response would be appreciated.
Note: In my country, most mechanics do a lot of guess work. The few automobile centres with full diagnostics will have you pay through your nose to check what is wrong first before they can start working on the car. I just said this because I may not have access to a proper diagnosis
Feb 14, 2017 at 5:00 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner then scan for codes which you will have to buy a scanner if none available for free check.
Feb 14, 2017 at 11:10 PM
ECALLY77
Alright. I am grateful. Though the car started when engine oil was filled. Will tell the mechanic to check your options. Thank you
Feb 15, 2017 at 5:19 PM
