Engine wont start and computer wont display any codes
JUSTINTIME
  • 1995 PLYMOUTH VOYAGER
  • 3.0L
  • 6 CYL
  • FWD
  • 125,000 MILES
Van was working fine and then I parked it, shut off engine and 15 minutes later I tried to start it again and it wouldn't start. It seems to crank over fine but wont start engine. I tried to check the engine codes but the fault codes display wasn't working either. I checked the coil and distributor cap they don't seem like they are getting any power and I replaced the pcm, looked over the fuses but I cant figure it out.
Friday, December 13th, 2013 AT 12:00 AM
  • 109,885 POSTS
Are you getting spark to the plugs? Have you checked fuel pump pressure.
Friday, December 13th, 2013 AT 5:08 AM
JUSTINTIME
Im not getting any spark at the plugs as far as I can tell and it doesnt sound like Im getting fuel either.
Friday, December 13th, 2013 AT 12:29 PM
JUSTINTIME
I got it working! I had checked everything except for the number 16 fuse on the inside of the van under the dashboard. Thanks I had found the answer on one of your other threads.
Saturday, December 14th, 2013 AT 1:16 PM
