2001 Dodge Intrepid Electrical Failures
RYAN L
I have a 2001 Dodge Intrepid ES 3.2L with about 64,000 miles. My first problem was when my 4 disc in dash cd changer started to jam with my cd's inside. Replaced it, one year later, same problem. Over time, cabin lights have randomly gone off and on, radio unit loses presets and then gets them back, time re-sets to random times, sometimes 12:00, dash lights and trip computer will go off then on, and most recently while driving in a -10 degree ice storm, my windshield wipers stopped working completely, along with the windshield washer fluid sprayers, and steering column controls for the radio seek and volume. Thank god for rain-ex. Turn signals and hazard lights seem to work fine though. It seems as if a circuit that controls the steering column components has gone out, but this would not account for the dash lights, cabin lights, trip computer, clock, etc. Electronic components will randomly go haywire and then return to normal, but wipers are now disabled all of the time. Any suggestions? I've heard that it might be the engine computer, but the engine seems to run fine, it's only the electronics that act up. I'm very afraid that my headlights will give out at a random moment while zooming down a dark highway. Dealer has been no help whatsoever, very frustrating for this potentially dangerous problem. Thank you very much.
Jan 17, 2007 at 6:54 AM
  • 75,988 POSTS
[quote:a3e057e195="Ryan L"]I have a 2001 Dodge Intrepid ES 3.2L with about 64,000 miles. My first problem was when my 4 disc in dash cd changer started to jam with my cd's inside. Replaced it, one year later, same problem. Over time, cabin lights have randomly gone off and on, radio unit loses presets and then gets them back, time re-sets to random times, sometimes 12:00, dash lights and trip computer will go off then on, and most recently while driving in a -10 degree ice storm, my windshield wipers stopped working completely, along with the windshield washer fluid sprayers, and steering column controls for the radio seek and volume. Thank god for rain-ex. Turn signals and hazard lights seem to work fine though. It seems as if a circuit that controls the steering column components has gone out, but this would not account for the dash lights, cabin lights, trip computer, clock, etc. Electronic components will randomly go haywire and then return to normal, but wipers are now disabled all of the time. Any suggestions? I've heard that it might be the engine computer, but the engine seems to run fine, it's only the electronics that act up. I'm very afraid that my headlights will give out at a random moment while zooming down a dark highway. Dealer has been no help whatsoever, very frustrating for this potentially dangerous problem. Thank you very much.[/quote:a3e057e195]
Have your battery and charge system check
Test the ignition switch and all the relays
Jan 17, 2007 at 7:52 AM
2CARPRO JACK
  • 11,533 POSTS
Has the BCM (Body Control Module) ever been replaced?
Jan 17, 2007 at 8:38 AM
RYAN L
I am the 2nd owner of the car, but I don't believe the BCM has ever been replaced.
Jan 18, 2007 at 5:59 AM
2CARPRO JACK
  • 11,533 POSTS
That and the main power relays would my starting point
Jan 22, 2007 at 7:56 AM
Suggested Repair
Start by testing the battery and charging system, the ignition switch, and all relays. Also check the Body Control Module and main power relays, since the BCM has not been replaced.
Conversation Summary
A 2001 Dodge Intrepid ES 3.2L has intermittent cabin and dash lights, radio presets and clock resets, trip computer dropouts, and now permanently inoperative wipers, washer, and steering-column radio controls. Turn signals and hazards still work and the engine runs normally. Experts recommend checking the battery and charging system, testing the ignition switch and relays, and starting with the Body Control Module and main power relays.
