1994 Dodge Intrepid Hard Start Fuel Smell
SHUDDERDWN
I have a 1994 Dodge Intrepid 3.3L with 208,880 miles. Just in the last couple of weeks it has been very hard to start (extended crank time) it also has a strong gasoline smell, inside the car, outside the car and under the hood you can smell it. But after the car starts it runs and acts fine until you have to shut it off again. I would appreciate any help you can give me. Thanks
shudderdwn
Nov 25, 2006 at 2:42 PM
  • 55,694 POSTS
First lets look at the fuel pressure regulator, remove the vacuum line to the regulator, if there is fuel present the regulator is bad and needs replacing. Next lets check the fuel rail itself, sometimes the rail can split causing fuel to leak out. Be careful with fuel problems - fire danger. :!:
Nov 26, 2006 at 7:28 AM
SHUDDERDWN
Appreciate the quick response and correct one by the way. The fuel pressure regulator was leaking fuel (very dangerous indeed) I am on my way to the parts store now to purchase. Thanks again for your quick and accurate response. You have earned my respect
shudderdwn
Nov 26, 2006 at 8:19 AM
  • 55,694 POSTS
Sweet :D
Nov 27, 2006 at 2:53 AM
Suggested Repair
Replace the leaking fuel pressure regulator. Also inspect the fuel rail for splits or leaks, and treat any fuel leak as a fire hazard.
Conversation Summary
A 1994 Dodge Intrepid 3.3L with high mileage was hard to start and had a strong gasoline smell inside, outside, and under the hood, but ran normally once started. The expert advised checking the fuel pressure regulator vacuum line for fuel and inspecting the fuel rail for splits. The owner confirmed the regulator was leaking fuel and planned to replace it.
