2000 Dodge Intrepid car cuts off and hard to start
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
PATTY5652
When i am driving about 65 or 70 on interstate rpm will go down to 0 and cut off. I will have to pull over to side of road and restart car then it is hard to start sometimes takes about 4 or 5 times to start. It will also buck at times and not cut off i will just see the rpms jump down and go right back up to normal. Any help will be appreciated . I am looking at the map sensor after reading about it on the internet. I got some CRC cleaner and sprayed it with it but did not help. I s there a way of testing the map to know if it is bad or not. There is no code coming up on the car. Thank you Patty
May 5, 2008 at 7:02 AM
JOHN410
Patty, I have a 2000 Intrepid also, with 170000k on it and was doing the same as yours. I replaced the Crankshaft Position sensor and that took care of the problem. It`s a very easy repair, it`s located back side of engine by transmissiom on the right side of car. Lying under car you can see it with a light, held on by two bolts.
Jun 4, 2008 at 9:15 AM
PATTY5652
I have been wanting to thank John410 for answering my question. You were right it was the sensor. Got it replaced and has been driving just fine Thank you again.
Patty
Aug 28, 2008 at 12:41 PM
