1995 Dodge Intrepid Overpressure
VIKEZFAN
  • 20 POSTS
I own a 1995 Dodge Intrepid. I am trying to decide if compression gases are getting into my cooling system. What it does is after running a few minutes, the pressure cap releases and blows out coolant. I have tried another cap. Until then, it runs cool. It overheats after blowing out coolant. The heater always blows cold. I have removed the thermostat just in case that was the problem. I have tried bleeding it, but it never get a constant stream of water.. always some air or gases in there. Also, if you think that compression gases are getting in there, is it just a head gasket replacement, or could it be something else? Any and all ideas will be appreciated.
Feb 23, 2007 at 3:23 AM
CHEVY22
  • 1,375 POSTS
dodge has a weird way to bleed the system but if this was happening before you removed the thermostat the problem is somewhere else , you can buy whats called a block tester and check for exhaust gasses in the cooling system or take it to the shop and have them do that and perform a cooling system pressure test , these two tests should point right at the problem , also check for coolant in the oil on the dipstick
Feb 23, 2007 at 3:28 AM
VIKEZFAN
  • 20 POSTS
Just a follow up on my problem. It was bad head gaskets. Replaced the head and intake gaskets and it fixed the problem.
Mar 25, 2007 at 3:52 AM
JSWINKERT
[quote:e55f1d59ac="VikezFan"]Just a follow up on my problem. It was bad head gaskets. Replaced the head and intake gaskets and it fixed the problem.[/quote:e55f1d59ac]
How long last the new head gaskets? Are u still using the car?
regards
Dec 19, 2008 at 11:02 AM
Suggested Repair
Confirm combustion gases in the coolant with a block tester and a cooling-system pressure test, and check the oil for coolant. The confirmed repair was replacement of the head gaskets and intake gaskets.
Conversation Summary
A 1995 Dodge Intrepid built cooling-system pressure after a few minutes, released coolant from the cap, then overheated. The heater stayed cold, bleeding never produced a steady stream, and removing the thermostat did not help. An expert recommended a block test for exhaust gases, a cooling-system pressure test, and a check for coolant in the oil. The owner later reported that failed head gaskets were the cause and that replacing the head and intake gaskets fixed it.
