Milky Oil / Blown Head Gasket
KTMRIDER
1998 Dodge Intrepid V6 75K miles
I am trying to repair this for my parents, so here is what I know. The car was allowed to overheat several months ago and there mechanic was very concerned the heads may have been damaged. Now the car will barely run and I have begun taking the right side of motor apart. Under the valve cover the oil is milky and thick. After removing the head I did not see anything wrong jumping out at me. I only took a quick look but could swear there was no head gasket unless it is blending in well. The Questions Are. Where do I go from here? How do you clean the sludge like oil? Can I re-assemble cam, lifters and chains exactly the way they were removed or do I need to replace bearings and etc.
Thank you for the wealth of knowledge
Jun 2, 2007 at 4:58 PM
2CARPRO JACK
  • 11,533 POSTS
First, with water in the oil, both heads should be removed and sent to a machine shop for pressure testing and surfacing. If ok, then reassemble if the bearings look ok.Once back together drain oil real good, refill and run engine for a few minutes, drain and change filter again
Jun 3, 2007 at 12:55 AM
KTMRIDER
Thanks for the reply, I guess I'm heading in the right direction.
Jun 3, 2007 at 6:13 AM
