1995 Dodge Intrepid No Start
FREEZE
  • 6 POSTS
My sons 95 dodge intrepid 3.5 with around 175,000m died the other day. There is fuel pressure and we checked the coil with a volt meter it seems to be in range. We pulled the #1 plug and it sparks once and only once when we turn it over. That lead me to believe that it was the crps. So we replaced that and still have the same problem. I tried to check the codes but they were cleared since he drained the battery trying to start it after it died. Now im thinking maybe cam sensor or possible the timing belt jumped. I can hear the valves open and close so I know it didn’t break. I have been told that it could be the map sensor. I really don’t want to put more money into it and then end up taking to a shop because none of it worked.
Apr 13, 2007 at 2:20 PM
  • 75,988 POSTS
[quote:5dc86f86bf="freeze"]My sons 95 dodge intrepid 3.5 with around 175,000m died the other day. There is fuel pressure and we checked the coil with a volt meter it seems to be in range. We pulled the #1 plug and it sparks once and only once when we turn it over. That lead me to believe that it was the crps. So we replaced that and still have the same problem. I tried to check the codes but they were cleared since he drained the battery trying to start it after it died. Now im thinking maybe cam sensor or possible the timing belt jumped. I can hear the valves open and close so I know it didn’t break. I have been told that it could be the map sensor. I really don’t want to put more money into it and then end up taking to a shop because none of it worked.[/quote:5dc86f86bf]
When you turn key On do you hear the pump for 2sec's?
Apr 13, 2007 at 8:49 PM
FREEZE
  • 6 POSTS
ya i can hear the pump. There is fuel pressure at the check valve.
Apr 13, 2007 at 10:07 PM
  • 75,988 POSTS
[quote="freeze"]ya i can hear the pump. There is fuel pressure at the check valve.
How much pressure? Don't think! because it has pressure it will start-if its not up to spec's it w/n start.
We know the pump is pumping, don't know how much? okay do this now go look for a spark while cranking then come back with the results and we'll take it to the extreme.
Apr 13, 2007 at 11:06 PM
FREEZE
  • 6 POSTS
There is fuel pressure. There isn't spark!!! When we turn it over it will spark one time and thats it no more spark. I replaced the crank shaft sensor same thing no spark. Something is shutting down the spark. If the fuel pump where bad it would still have spark.
Apr 14, 2007 at 6:31 AM
  • 75,988 POSTS
If it has one -investigate the ASD relay this one powers both coil and pump.
Apr 14, 2007 at 12:57 PM
FREEZE
  • 6 POSTS
I believe that you talking about the relay in the fuse box under the hood. I have checked them and they are good. Would a bad map sensor cause it not to spark ?
Apr 15, 2007 at 5:02 AM
  • 75,988 POSTS
[quote:706549fe14="freeze"]I believe that you talking about the relay in the fuse box under the hood. I have checked them and they are good. Would a bad map sensor cause it not to spark ?[/quote:706549fe14]
Try the crankshaft position sensor.
Apr 15, 2007 at 9:57 AM
FREEZE
  • 6 POSTS
Already replaced that
Apr 15, 2007 at 8:48 PM
FREEZE
  • 6 POSTS
Brought it to the shop. The timing belt jumped some teeth. Thanks for the Help
Apr 19, 2007 at 4:34 PM
Suggested Repair
The no-start was traced to a timing belt that had jumped teeth. Have the timing belt and cam/crank timing inspected and corrected rather than replacing more sensors.
Conversation Summary
A 1995 Dodge Intrepid 3.5 with about 175,000 miles died and would not restart. Fuel pressure was present and the fuel pump primed, but the plug sparked only once while cranking. Replacing the crankshaft position sensor and checking the ASD relays did not restore spark. The owner later took it to a shop, which found that the timing belt had jumped some teeth.
