1995 Dodge Intrepid No Spark No Start
HARNISH
I got home from work the other night and the car worked fine, but then this morning it wouldn't start as if it had no spark to the spark plugs. I checked the spark and again no spark. I checked power to the coil and no power. I replaced the Engine computer and still no power. One thing I have noticed is that the engine is filling the cylinders with fuel to the point where it will not turn over due to the pressure. I need to know what could cause this and why this is happening. I don't think the fuel is supposed to build up in all the cylinders. Can anyone help me on this? Thanks for your time.
Sep 8, 2007 at 9:54 AM
  • 75,988 POSTS
[quote:f8192ed735="harnish"]I got home from work the other night and the car worked fine, but then this morning it wouldn't start as if it had no spark to the spark plugs. I checked the spark and again no spark. I checked power to the coil and no power. I replaced the Engine computer and still no power. One thing I have noticed is that the engine is filling the cylinders with fuel to the point where it will not turn over due to the pressure. I need to know what could cause this and why this is happening. I don't think the fuel is supposed to build up in all the cylinders. Can anyone help me on this? Thanks for your time.[/quote:f8192ed735]
Direct power to coil-on the dark green wire at the coil connector pin 4-this will bypass the ASD relay
Take a jumper wire with a 10amp fuse in it-hook it up to the coil pack connector pin 4 and the other end to the battery positive-if it starts-either you a problem with ASD relay or an open circuit on the dark green wire going to the coil connector.
The ASD realy powers the coil and the injectors/fuel pump thru the FP/ relay.
Good Luck
Sep 8, 2007 at 3:00 PM
Suggested Repair
Bypass the ASD relay by feeding fused battery power to coil connector pin 4 on the dark green wire using a jumper with a 10-amp fuse. If the engine then starts, repair or replace the ASD relay or the open dark green coil power circuit. The ASD relay also supplies the injectors and fuel pump through the fuel-pump relay, so address that circuit before cranking a fuel-flooded engine.
Conversation Summary
A 1995 Dodge Intrepid 3.3L that ran fine the night before would not start the next morning. The owner found no spark and no power at the coil, and replacing the engine computer did not restore power. Fuel was also filling the cylinders enough to prevent the engine from turning over. The expert advised applying fused battery power directly to coil connector pin 4 on the dark green wire to bypass the ASD relay. If that restores starting, the ASD relay or an open dark green wire is at fault; that relay also powers the coil, injectors, and fuel pump.
