1998 Dodge Intrepid Cold No-Start
LANA92178
my car is a 1998 dodge intrepid es with 172,000 miles on it when we have cold weather it will not start
Jan 11, 2007 at 3:00 PM
SERVICE WRITER
  • 9,123 POSTS
How old is the battery?
Jan 11, 2007 at 7:32 PM
LANA92178
ive had the car for five years it was bought used so i dont know. i did have the battery tested the shop said there was nothing wrong with it. they think its the computer brain and saying the memory card is bad and thats whats causing the problem. does anyone know about this
Jan 12, 2007 at 5:20 AM
SERVICE WRITER
  • 9,123 POSTS
If you have had the car for 5 years and did not put a battery in it then you should regardless. Are they checking it when it doesn't start? The battery may be borderline and fails when cold, but recharges when warm.
Jan 12, 2007 at 5:27 AM
LANA92178
they said they checked the battery when it was cold
they said they have never seen a car do that thats why their convinced its the computer brain. but i dont understand everything else works fine with the car
Jan 12, 2007 at 5:59 AM
SERVICE WRITER
  • 9,123 POSTS
Do you smell raw fuel when it isn't starting from under the hood?
Jan 12, 2007 at 6:36 AM
LANA92178
yes
Jan 12, 2007 at 8:13 AM
SERVICE WRITER
  • 9,123 POSTS
HAve the fuel rail checked. when it's cold the metal contracts and fuel eccapes. There is a saftey bulletin on potential fires with this. First contact the dealer service dept. HAve your vin ready. Tell them you think you may not have had a recall on the fuel rail performed. This should be at no charge.
It is certainly possible this is not the "magic bullet" But why not start with the possibility of free? And safe :wink:
Jan 12, 2007 at 8:19 AM
Suggested Repair
Have the battery rechecked when the car will not start in the cold, since an older battery can fail only when cold. Because raw fuel is smelled, have the fuel rail inspected for cold leaks and contact the dealer with the VIN about a possible no-charge fuel-rail recall and fire-safety bulletin.
Conversation Summary
A 1998 Dodge Intrepid with 172,000 miles will not start in cold weather. The battery tested fine and a shop suspected the computer, but the owner said everything else works. After the owner confirmed a raw-fuel smell, the expert advised checking the fuel rail for leaks caused by cold contraction, contacting the dealer with the VIN about a possible unpaid recall and fire-safety bulletin, and still considering battery age.
