1997 Dodge Intrepid Electrical Shutdown
REDDEATH65
Dodge, Intrepid ES, 1997, 144,000 not sure of engine size
Here are my 2 problems, when I was driving the Electric shut down on my car ( power windows, ac would not work) the ABS and air bag lights came on, after about 25 seconds the problem stopped and my elecrtic returned. This is the second time this has happened
My other question is, when I use my power locks to open, the drivers side lock makes a funny noise and does not open the other 3 doors do unlock. I can lock the car with no problem using power locks.
Any Ideas????
Thank you
Jun 9, 2007 at 4:36 AM
E40WATER12
  • 522 POSTS
For youre power door lock issue, I would thing youre power aculator motor that moves lock & unlock has failed, New is needed, Also electric shut down u are having could be a problem with youre battery, Could have a cel dead, Cause the battery not to allow other electronics to function properly. Just make sure youre battery is full charged, Also alternator is charging the battery as well.
Jun 9, 2007 at 10:26 AM
Suggested Repair
Replace the failed driver's door lock actuator. For the brief electrical shutdown, test that the battery is fully charged and that the alternator is charging it; a weak or dead battery cell can interrupt other electronics.
Conversation Summary
A 1997 Dodge Intrepid briefly lost power windows and A/C while the ABS and airbag lights came on, then recovered after about 25 seconds; this happened twice. The driver's power lock also makes a noise and will not unlock, while the other doors unlock and all doors lock normally. The expert attributed the lock issue to a failed actuator motor and suggested checking battery charge and alternator output for the electrical shutdown.
