2002 Dodge Intrepid interior door handle
SID THE KID
Interior problem
2002 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
i own a 2002 dodge intrepid r/t, front passenger interior door handle is broken inside the panel (has a little plastic eye the rod sits in that broke off). do i have to replace the entire panel or does the handle come out ? if the handle comes out is there a way to fix it without replacing it? thanks
Jun 15, 2008 at 3:27 AM
MERLIN2021
  • 17,250 POSTS
There is only 1 bolt that holds em on, weather it's on top, or the front...if it's on the front you should be able to see it when you pull it to open, if not, you need to remove the trim panel, If the eye is broke off, you need a new one.
Jun 15, 2008 at 3:34 AM
CNWK64
I have the exact same problem. but I can't find parts to replace it. can anyone provide me a link where I can buy the part to replace it? local dealer wants to charge me $150 + tax just for part.
Sep 3, 2008 at 9:56 AM
MERLIN2021
  • 17,250 POSTS
Try a junkyard...or junkyard websites.
Sep 4, 2008 at 9:52 AM
