2002 Dodge Intrepid PASSENGER SIDE INTERIOR DOOR HANDLE
2002 DODGE INTREPID
130,000 MILES • 6 CYL • FWD • AUTOMATIC
SHAWN6638
THE PASSENGER SIDE DOOR HANDLE (INSIDE) WILL NOT OPEN DOOR... HOWEVER, THE EXTERIOR HANDLE OPERATES FINE. HOW CAN I DIAGNOSE THIS PROBLEM AND FIX IT?
Jun 21, 2009 at 12:26 PM
  • 110,244 POSTS
Chances are the linkage came disconnected or has actually broken. You need to remove the door panel to access the linkage. Once removed, you will be able to identify where the problem is.
Jun 22, 2009 at 3:26 PM
LPROWSE1
I have the same problem. Removed the door panel and it is the linkage broken. Ordered and recieved new door handle. Now how do I remove the door handle to replace it?
Jun 30, 2012 at 8:08 PM
