1996 Dodge Intrepid Hard Start After Warm
BMILLSPAUGH
I have a 1996 Dodge Intrepid, 3.3L engine, automatic transmission with 196,000 miles on it. This car is very hard to start after it has warmed up and been shut off for more than 5 to 10 minutes. It will start right up if it has been sitting for a week without having been started. After it has been started and has warmed up, if it is shut off, it will start by just bumping the starter within two or three minutes. If it sits for 10 minutes, it will be very hard to start and run and smell like it has been flooded immediately after starting. The engine will smooth out after a few seconds of running and be just fine. There is a gassy smell in the engine compartment, but I can't find any fuel leaks.
Oct 27, 2007 at 10:13 AM
2CARPRO JACK
  • 11,533 POSTS
I have seen both the fuel injectors and fuel rails leak on those cars. sometimes fuel leaks are hard to find, it dries so quickly on a warm engine.If you remove the upper intake, you can cycle the key for fuel pressure and it is alot easier to see everything.I do suggest that you have it seen to immediately.
Nov 4, 2007 at 12:51 AM
BMILLSPAUGH
I took the car to a mechanic friend of mine who spent a couple of hours trouble shooting. He found a bad fuel regulator tnat was causing flooding of the car after the car had been run for a little while. If the car was started immediately, the flooding was not enough to make it hard to start. If the car sat long enough, sufficient fuel was leaked into the intake plenum to flood the engine so it was hard to start. If it sat long enough, the fuel would dry up and no longer flood the engine.
Nov 7, 2007 at 11:58 AM
Suggested Repair
Replace the faulty fuel pressure regulator that was leaking fuel into the intake and flooding the engine after a short hot soak. If symptoms continue, inspect the fuel injectors and fuel rail for leaks.
Conversation Summary
A 1996 Dodge Intrepid with a 3.3L engine started easily when cold or after sitting a long time, but was hard to start and smelled flooded after being shut off warm for about 10 minutes. An expert suggested checking for leaking fuel injectors or a leaking fuel rail, which can be easier to see with the upper intake removed while cycling the key. A mechanic later found a bad fuel pressure regulator leaking fuel into the intake plenum and causing the hot-soak flooding.
